App Update Version 3.1
Discussion in 'Announcements' started by iMatt, Jun 1, 2016.
Thread Status:
Not open for further replies.
    • Like x 3
  2. Roy M
    Roy M New Member
    Great news!!
  3. Debbie
    It is in the Apple Store now in the US.
  4. Gerd Schmitt
    Gerd Schmitt New Member
    Hi Matt.
    Update 3.1 is absolutely great. To quote Tim Cook : "It´s absolutely amazing ...."
    But I have one question: could it be that after the update to 3.1 in some cases, the concordance is
    selectable in the German version ? You said that this would be possible only in the English version .
    With me the concordance , in which I could select English words appeared . However, I can not reproduce it for time .
    Best regards
    Gerd
    Hi @Gerd. It is always possible there is a bug in the code, but I cannot see any issues.
    To clarify - there are multiple ways of getting to the Search window. If the search is launched from the button on the top toolbar, then it will be searching your "Preferred Bible". If this is either the "nwt_E" or the "bi12_E" then it will show the Concordance tab. So this will depend on what Bible is your "Preferred Bible" at the time you click this button.
    You can also launch the Search window from the buttons above the verses in the side-by-side view. So if you launched the search from the buttons above the nwt_E or bi12_E then again it will show the Concordance tab.
    Hope that helps clarify things.
  6. Gerd Schmitt
    thank´ s for your answer - now I can reproduce it.
    But: It´ s not a Bug, it´ s a Feature!
    So people like me, who speak a little bit English, can so use the Concordance too.
    Please don´ t fix it!
  7. Hope
    Hope New Member
    Really great app. Love it. Just with newest version 3.1, it mentions I should be able to highlight a phrase ( your ex was in yellow) and also use the <i>, <b> formatting. Can't seems to find how I do this . Does it matter if I have an iPad 2? Thanks, and thanks again for such a great app.
  9. Gabriel
    Thank you a lot for cross-references and footnotes for French NWT (bi12-F). That's perfect like that but you know it's not perfect? ))))
    For example, in Psalm 27:4. the footnote for "temple" is in the first "temple" in the verse in the word 'contempler' = contemple*r
    I didn't realise. Thanks for letting me know. Can you please type this up as a new Bug report.
  11. Hope
    Hope New Member
    Thankyou! Finally worked this out. I was using another formatting, and although some of it worked, it did not show up on the side panel. But now I "see" the proper formatting, and it is working perfectly. It is amazing, will even love using it more now. Sorry it takes so long for things to sink in!!
    Thanks again for such a "great " app.
Thread Status:
