Planned From the Chapter Window, lookup a verse in the main Bible window (side-by-side view)
Discussion in 'Feature Requests' started by Erngab, Apr 27, 2017.
  1. Erngab
    Erngab New Member
    I will explain through an example.
    I come to whole chapter page from Genesis 17:1.
    I am on whole chapter page, and I want to see parallel Bible translations (Serbian, Hungarian, English, other translations...) for Genesis 17:7.
    Long press to verse 17:7 and from context menu I go direct to the parallel Bible translations for Genesis 17:7.
    [​IMG]
    In the whole chapter window you can already double-tap (or triple-tap depending on your settings) to switch between the parallel translations.
    It is not likely I will add a button to do this sorry.
  3. Erngab
    Erngab New Member
    I know double-tap
    I want to go directly to verse 17:7 (picture)
    [​IMG]
    I see. You want to close the fullscreen Chapter Window and return to the Parallel view, with that verse open.
