Idea Study with Strong's numbers in alternate languages
Discussion in 'Feature Requests' started by Gabriel, Aug 12, 2015.
    I really like used the King James with Strong.
    OT <a href="06153" class="strongs">
    NT <a href="281" class="strongs">
    With what I find on that website (http://www.obohu.cz/bible/) , I have some ideas!
    1. Have the master text of NWT with Strong (same Strong that King James, or see idea 3) :
    • Westcott-Hort NT with Strong numbers and morphology (http://www.byztxt.com/download/)
    • Westminster Leningrad Codex with Strong’s numbers
    • Biblia Hebraica Stuttgartensia with Strong’s numbers
    • Biblia Hebraica Stuttgartensia (Consonants & Vowels)
    2. Have others versions with Strong number
    • Russian Synodal Translation - with Strong number (RU) (Russian New Testament Strongs)
    • Louis Segond 1910 (FR) - with Strong numbers (copyright)
    • Webster Bible (1833) - with Strong numbers (EN)
    • Luther Bible (1545 - GER) - with Strong numbers
    • Luther Bible 1912 (GER) - with Strong numbers
    • Elberfelder Bible (1905) - with Strong numbers (GER)
    3. Can select the source with the numbers Strong. (for me, it is interresting to have it in French or in Russian) :
  2. Gabriel
    Thanks for the ideas Gabriel. As you mention the Equipd Bible app already supports the King James with Strong's, and you can generate additional bibles to point to the Strong's references using the link format you included.
    I will keep these additional ideas in mind for the future, but it is not likely to be a high priority relative to other features that I need to work on. But maybe one day!
    Thanks again for your enthusiasm for the Equipd Bible app and all the Bibles that you have been contributing :)
  4. Gabriel
    Ok! In next update, others files without the name "KJV-S" will work or actually?
    And if you can add a line for the type of word "preposition", conjunction, verb, name, etc...
    <p><a id="c3_v1"></a><span class="vn">1</span>
    <gr str="1722" rmac="prep">εν </gr>
    <gr str="1161" rmac="conj">δε </gr>
    <gr str="3588" rmac="t-dpf">ταις </gr>
    <gr str="2250" rmac="n-dpf">ημεραις </gr>
    <gr str="1565" rmac="d-dpf">εκειναις </gr>
    <gr str="3854" rmac="v-pni-3s">παραγινεται </gr>
    <gr str="2491" rmac="n-nsm">ιωαννης </gr>
    <gr str="3588" rmac="t-nsm">ο </gr>
    <gr str="910" rmac="n-nsm">βαπτιστης </gr>
    <gr str="2784" rmac="v-pap-nsm">κηρυσσων </gr>
    <gr str="3588" rmac="t-dsf">τη </gr>
    <gr str="2048" rmac="a-dsf">ερημω </gr>
    <gr str="3588" rmac="t-gsf">της </gr>
    <gr str="2449" rmac="n-gsf">ιουδαιας </gr>
    I can confirm in the next update that the standard links (shown below) already used in the KJV-S ePub file will also work for other ePub files - i.e. those without the name "KJV-S".
    Code:
    There will not be any other changes around this in the next update however sorry.
  6. Gabriel
    I did change in all 7 versions with Strong in Contributed Bibles
    (I learn to make "regular expression" and now I can make things more faster!)
    with version with only "> after the number
    ([0-9][0-9][0-9][0-9]) = \1" class="strongs
    \<a href="([0-9])" = a href="\1" class="strongs"
    with version with " rmac=".*?"
    \" rmac=".*?"> = " class="strongs">
    </gr> = </a>
    <gr str=" = <a href=" (NT)
    <gr str="G = <a href=" (NT)
    <gr str="H = <a href="0 (OT)
    Sometime 2 number strong.... What doing with that?
    <a href="1080 5681" class="strongs">εγεννηθη </a>
  7. Gabriel
    If one day you can add french lexicon for the Strong Number! Greek lexicon list included at the end of the chapter.
  8. Gabriel
  9. Gabriel
    When the next update? :)
  10. Gabriel
    Dictionary Strong in French
    Having the option of definions Strong like KJV English but in French! )))
    I can not wait to have this option in Equipd! ))):):):) I hope in upcoming update! :):):)
    If Equipd will allows to make Epub with all chapters or books in one file, it will be simple to put strong number in footnote only in the Epub file.
    Here is the source in .docx, no problems using it with permission. - prohibited without prior authorization.
    https://logosfreelibrary.wordpress.com/2013/12/01/strong-dictionnaire-dhebreu-et-de-grec-dhg/
    I made the french lexicon of Greek part (40.MT.1.txt) with the permission of Richard Helleme (hochylap@gmail.com).
    There is an update of the Greek lexicon underway, Richard wrote me.
    R. Helleme, Greek-French-English Lexicon of the New Testament (2013)
    http://docplayer.fr/2269793-Lexique-grec-francais-anglais-du-nouveau-testament.html
  11. iMatt
    This thread has quickly moved away from being about loosening the existing special links in the app that were only enabled for the KJV-S file.
    As mentioned in a previous post...
    And I changed the thread label to "Ready for Next Update".
    However this thread is listing all types of ideas about adding support for the Strong's Numbers in French etc. These have not even hit the "planned features" list, so I have changed the status of this thread back to "Idea".
