Fixed - 3.0 Pop-ups in Split Screen view
Discussion in 'Bug Reports' started by niall, Mar 22, 2016.
  1. niall
    Firstly, I love the latest update.
    When Equipd is run in split screen mode and I tap a note, the note window doesn't fit the split screen window. That happens even if Equipd is the primary app (on the left).
    I'm using an iPad Air 2 and iOS 9.3 (public release, not Beta).
  2. Baerwurzl
    I can confirm this bug
    Thanks for reporting this. Can't believe that neither I, nor my beta testers, picked up on this.
    I suspect most of my testers using the split screen feature are either on the larger iPad Pro, or using the 9.7" iPad in landscape mode. If you rotate your device, the size of the notes screen should fit ok.
    I will improve this in the next update.
  4. Baerwurzl
    Rotate doesnt help like you know i use an iPad mini
  5. niall
    This was in landscape mode. Plus, it also does the same when viewing Strong's definitions - although, I guess, you're using the same function for both cases.
    By the way, I'm happy to be a Beta Tester if you like.
    Fixed for the Notes window, plus the Strongs Concordance and Footnotes popup windows.
