Fixed Missing verse numbers on copied scriptures - Slide Over & Split Screen
Discussion in 'Bug Reports' started by Joey M, Feb 17, 2019.
  1. Joey M
    Joey M New Member
    The latest update removed the verse numbers on copied scriptures.
    Using iPad pro.
  2. Joey M
    Joey M New Member
    Playing with it a bit more, I realized the bug is when I slide Equipd Bible over my note taking app, known as 'Slide Over' . It also happens with split screen. It will copy the scripture as follows:
    2 Co 5 — for we are walking by faith, not by sight.
    NO VERSE #!!
  3. Klarika
    Klarika New Member
    This is also happening for me. I thought it was part of the new design. Apparently it is not intended? And thanks for solving the mystery of when it happens!
  4. Karen
    Karen New Member
    I’m having the exact same problem since the update. Also it keeps shutting down on me.
  5. darylpro
    darylpro New Member
    I confirm the same behavior, when Equip Bible is in Split View at 1/3 size on the right or the left. It is working correctly when Equipd Bible is split 50/50 or in split view at a 2/3 size on right or the left.
    Yes I can confirm the copy scripture issue happens when the app is in Split Screen mode, on the smallest 1/3 size. I have located the issue which will be fixed in the next update.
    @Karen the copy scripture issue should not be related to any crash or the app "shutting down" - can you please provide more details on your comment about this? Ideally in a separate forum thread, or via email to support@equipd.me.
    Version 3.8.1 is out now - can you confirm that this has fixed the issue for you?
  8. Karen
    Karen New Member
    Yes, just tested it out, and works perfectly again. Thank you so much for your hard work and timely attention to this issue.
    Karen
