Planned Improved handling of opening lots of verses side-by-side
Discussion in 'Feature Requests' started by iMatt, Jun 27, 2015.
    At the moment if a user tries opening up many verses in the side-by-side view, it could cause the app to crash. For example if the user has 5 Bibles loaded side-by-side and decides to try viewing the whole chapter, it opens too all verses x5 Bibles, and app/device just cannot handle this much content.
    I will likely put a hard limit on the number of verses that can be opened in the side-by-side view. Any excess of this selected by the user, will cause an alert and the app will only show the number of verses up the the limit set.
    Important Note:
    If this happens to you, and the app crashes, you can resolve the issue in the iOS Settings > Equipd > and enable the "Clear Scripture History" option. The next time you open Equipd it will clear out the multiple verses and default to opening 2 Timothy:16,17.
