Idea Import/Export Notes
Discussion in 'Feature Requests' started by Carlos, Aug 16, 2016.
  1. Carlos
    Carlos Member
    I would find it very useful to be able to write notes in a CSV file or similar and import them all at once into the bible of my choice with the choice of appending to or overriding existing notes. Exporting to a file that could be edited and reimported would also be a great addition for me. I am enjoying using this app. Thank you;
    Carlos
    Hi Carlos, although this is not yet "built in" you can in reality already edit the bookmarks outside of the app if you are able to work with JSON.
    The bookmarks simply JSON files. You can access them inside the backup ZIP file. And you can also access them via iTunes File Sharing. Which means that you can update the JSON files on your computer and then restore them to the app.
