Exporting/ importing notes
Discussion in 'General Questions' started by DvD, Apr 14, 2021.
  1. DvD
    It might be too much to ask but is it possible to export notes in Equipd Bible to JWLibrary and/ vice versa? Thank you
    Post #2 by iMatt, Nov 21, 2021
    It is likely possible by looking at the database file generated by JW Library, however I am not sure such a feature would comply with the Terms of Use on JW Library sorry. There are some tools around for merging multiple JW Library files together, but that is still to use it again inside JW Library - not to use in a different tool altogether. I will ponder further, but my initial reaction is to avoid any issues in that area.
