Fixed - 3.0 Editing bookmark comments not saving
Discussion in 'Bug Reports' started by niall, Mar 22, 2016.
  1. niall
    Adding a comment when creating a bookmark works great - and is a feature I would have never thought of. But, edits made to a comment, from the bookmarks view, are not saved. The same goes for adding a comment to an existing bookmark. Unless I'm doing something wrong.
  2. Baerwurzl
    Imcan confirm this bug
    Thanks for letting me know about this. I have had this happen sometimes, but can never "force" it to happen so that I can locate the issue.
    I have found restarting the app seems to fix the issue for whatever reason.
    I will look into it further...
  4. Baerwurzl
    Force restart worked. So no problem. Thank you!
  5. niall
    Yes, restarting the app seems to fix the problem. Thanks.
    I think I have found the underlying issue with this. Improved in the next update.
