Done - 3.0 "Long Press" on a verse number for options
Discussion in 'Feature Requests' started by iMatt, Mar 30, 2016.
    Sometimes it is handy to be able to perform different actions on a verse without having to select it from the top navigation buttons.
    There is now a new option of a "long press" on a verse number, to be presented with different actions:
    1. If you have the Web Search enabled in your Settings, then you will be able to perform a search on that verse.
    2. You can bookmark the verse. Also handy in the Chapter window, where previously you have not been able to bookmark scriptures.
    3. You can Add or View a Note for the verse.
    Other options will be added over time.
    Sample screenshot shown below from tapping + holding on verse "6" in the Chapter Window for Matthew 24...
  2. Bohemian
    Bohemian New Member
    That's great, Matt!
