The developer of ReadingPlan has added official support for Equipd, which means it is even easier to integrate the two apps. Please open ReadingPlan > Settings and follow the steps in the attached screenshots... --- You can also integrate with ReadingPlan manually. Once you have installed the ReadingPlan app, then open ReadingPlan and go into Settings and add a new custom "Bible Link" for Equipd with the following format... Code: equipdbible://bible/%@ Note: If you copy and paste this link into ReadingPlan, make sure there are no trailing spaces in the link!
Hello Debbie. Assuming you have the ReadingPlan installed on iPad or iPhone, open the app and tap the top-right corner to get to Settings. You should have a list of bibles there already. Tap 'edit' to add a new one, just tap on the Bible link. For the name I used 'Equipd Bible'. Then paste the URL name 'equipdbible://bible/%@' without the quote mark. Make sure there are no spaces before or after the URL name. When done you should see the new bible link name. You should be good to go.
@Roy M and @Website Hugger - thanks so much for helping answer that one! Great stuff. Out of interest the developer of ReadingPlan just contacted me to let me know that he will indeed add the Equipd Bible app to the default list of supported Bibles which is great news. I will post on here when he has confirmed it as done.
Worked great for me. He is helpful there. I created a 'plan' there, called it "one year seasonal", started the year in Genesis, then proceed through the year based on the weather really. In the summer I read through the books that are maybe more challenging for me, then when the weather is bad, the easier books. I also go through the gospels during memorial season. That app, combined with the plan I wanted and Equipd have really helped make it easy to keep up with a one year read because I know exactly where I am supposed to be.
3 Reading Plan : 1) JW364.ini - JW One Year - Bible Reading Schedule like the pdf with 364 days. 2) 261week.ini - Reading of the week - The program on five years who started on January 1, 2014 . In the settings, choose: Titles - Week 40. 3) Finalweek.ini - Final week of Jesus - The 9 days reading program for the memorial. Next start date : March 18, 2016. 1) Change the extension : .txt to .ini 2) On your computer, open Itunes and connect your Iphone or Ipad. 3 ) Add file like this : https://support.apple.com/en-us/HT201301 4 ) Sync 5 ) Open "ReadingPlan on your Iphone or Ipad. 6 ) Open Settings 7 ) Reading Plan : choose one 8 ) Bible Link - View Available Links - Equipd Bible - Add - Select "Equipd (App)" 9 ) Back to Setting - select Start Date and the Titles format with date. 10 ) Done Because Reading Plan is for bible chapter, Equipd is more faster if you have not many version of the bible active and/or in the bible settings you chose the option "Stop the selection at chapter". With ios 9, in Equipd, with "slide from left side" you have the chapter to read from "ReadingPlan" app and there is the call back option top-left (also great with the Equipd javascript in epub). Jim Price of ReadingPlan App, "I just updated the link file so it passes the full verse range. To update your link, delete the existing Equipd link and download it again."
HI all, To link the Watchtower Online Library NWT 2013 Bible to Reading plan, paste the following link as the URL: http://wol.jw.org/en/wol/binav/r1/lp-e/nwt/E/2013 This is great for doing research on a scripture. Love this ...
