This is the Weekly Bible Reading Schedule used by Jehovah's Witnesses for 2023. How to install: Download the attached file "weekly2023-schedule.zip" in Safari. Locate the downloaded file in the Files app > Downloads folder. Tap+hold on the ZIP file and from the popup menu choose to "Share" to the "Equipd Bible" app. Note: If you do not see the Equipd Bible app in the "Share" list, then click on "More" to show additional apps and select it. The Bible app should open, and you should get a message saying that the schedule was successfully installed. You will then see the schedule listed under "Downloaded Schedules" inside the Bible app. Make sure you set the Study Week for the Schedule (typically the day after your midweek meeting). PS - If you have trouble installing the schedule ZIP file on iOS 13+, maybe some of the details on this forum post will help you.
