This is the Weekly Bible Reading Schedule used by Jehovah's Witnesses for 2021. How to install: Download the attached file "weekly2021-schedule.zip" in Safari. Locate the downloaded file in the Files app > Downloads folder. Tap+hold on the ZIP file and from the popup menu choose to "Share" to the "Equipd Bible" app. Note: If you do not see the Equipd Bible app in the "Share" list, then click on "More" to show additional apps and select it. The Bible app should open, and you should get a message saying that the schedule was successfully installed. You will then see the schedule listed under "Downloaded Schedules" inside the Bible app. Make sure you set the Study Week for the Schedule (typically the day after your midweek meeting). PS - If you have trouble installing the schedule ZIP file on iOS 13+, maybe some of the details on this forum post will help you.
Hi! For some reason my Weekly Bible Reading Schedule that just downloaded shows the reading this week is Judges 15 and 16 instead of Leviticus 16 and 17. Is there a way I can fix that? Thanks a lot in advance for your help! Greg
Good morning! Thank you for making the 2021 wheeling bible reading schedule available. However, I have the same issue as Greg: this week says Judges instead of Leviticus; I tried your suggestion, but it still says Judges :-( Any assistance is greatly appreciated! ~Cherr
I think the problem is that it has not yet hit Monday 4th January in your country / timezone. So the schedule is showing you the week 53 scheduled item from the end of the schedule. Because it is a “weekly” schedule It is not based on specific dates, but rather on the week number. I suggest just waiting until Monday and everything should come right - or manually move forward a day using the arrows on the Schedule screen. @Greg Díaz @Cherr H.
