Some users are asking how to turn off the trumpet sound that is part of the reminder to do your Daily Bible Reading. Here are the two ways you can control these reminders. Option 1) iOS Notification Settings This alert is just a standard iOS Notification, the same mechanism used by most apps on your device. Go to the generic iOS Settings screen. Scroll down until you find the "Notifications" section. This is where Notifications and Alerts for all apps on your device can be managed. Scroll down until you find the "Equipd Bible" app. You can turn off the "Sound" option. This will disable the trumpet sound. You can also control other aspects of the notification from this screen. The lesson here is that any app that is alerting you with notifications or sounds can be controlled from this section of the iOS Settings. Option 2) Equipd Bible App Schedule Settings From within the Schedules module inside the Equipd Bible app you have the ability to disable these reminder notifications altogether, or to change the time of the notifications. By default they are set to 7:01am and 6:30pm - but you can change them to be whatever time suits you best. Or just turn off one or both notifications so that they don't happen at all. Open the Equipd Bible app. Click the open Book icon in the top toolbar. Click the last Tab button along the top - it looks like a Calendar. On the left of the toolbar is a Settings button. Along the top is 2x Tabs - Schedules & Settings. Click the "Settings" tab. From here you can disable each Notification altogether, or change the time of each notification.
