Highlighting?
Discussion in 'General Questions' started by Bohemian, Jun 26, 2015.
  1. Bohemian
    Bohemian Member
    hi, great to see the app back!
    The illustrations appear to show word highlighting, how is this accomplished?
    Also, how does one enter double-quotes into the text?
    Thanks for all your help.
    Post #2 by iMatt, Jun 27, 2015
    These are inside the verse notes. To add a note to a verse, just tap on the verse number. And then inside your note, if you "double-quote" a word inside the verse it will become a link. Give it a go and see how you get on.
    Update: You can also now refer to the new article in the Knowledge Base on how to create links inside notes.
  4. Bohemian
    Bohemian Member
    Thanks, Matt.
