Fixed - 3.2 Cross-references and footnotes for bi12-F
Discussion in 'Bug Reports' started by Gabriel, Jun 27, 2016.
    Thank you a lot for cross-references and footnotes for French NWT (bi12-F). That's perfect like that but you know it's not perfect? ))))
    For example, in Psalm 27:4.
    - The footnote for "temple" is in the first "temple" in the verse in the word 'contempler' = contemple*r
    - The first "Jéhovah" have two ++, the second "+" is for the second "Jéhovah" in the verse.
    If you look in your (bi12-S), both problem are ok.
    (same kind of problem in Gen 3:5, footnote in first "Dieu" but if for the second "Dieu".
  2. Gabriel
    Just to let you know that it would be nice to make links workings to WOL for the Appendix , which are not included in the Epub file. Or if you can do the same like footnotes?
    For example here : 1D
    The main issue reported in this thread is fixed I believe. See screenshot below.
    The other request about links to WOL etc is not related to the initial thread topic and should be moved to a new thread.
