FAQ Can you add another Bible?
Discussion in 'Knowledge Base' started by iMatt, Jun 29, 2015.
  2. CesarGarcia86
    CesarGarcia86 New Member
    Thanks for supplying the details. Those details are typically supplied as part of a request asking me to generate the EPUB for you. I cannot see any confirmation that the requested Bible is in the Public Domain, and not protected by copyright.
    There is nothing stopping you preparing an ePub for your own use. Please go ahead. I mentioned to you previously to read the subheading "Create Your Own EPUB Files" at the start of this thread. I will post it here for you again...
  4. Peter
    Peter New Member
    CAn the following B
    ible be added
  5. Peter
    Peter New Member
    This Bible is under copyright as it says at the start of the PDF:
    Although this might not be a problem per se as they seem to indicate it is viewed as a Public Domain work.
    Also it would be good if I can see this in HTML/web format somewhere as I cannot generate the Bible from a PDF sorry.
  7. Gabriel
    Edition 2009 : http://www.bible.is/MAHWGM/Gen/1
    @Gabriel excellent thanks for the link. I am not sure if/when I will personally be able to generate this Bible, but will keep a note for the future.
  9. Peter
    Peter New Member
    Hi Matt and Gabriel
    Thank you for your help with this. I have managed to get the Bible in docx format which I then can save in Note++ as an xml or .txt file. If I can get all 66 books into separate files with one chapter per line, will this help? I have uploaded Genesis by way of example.
    Look forward to hearing from you.
    Peter
  10. Gabriel
    If you make 1189 files (one by chapter) in txt or xml, I can make the bible in 10-30 minutes for Equipd.
  11. Peter
    Peter New Member
    Thx Gabriel - lots of work! We will get started and get the files to you. Any particular naming or Gen 1.txt, Gen 2.txt, etc. is ok? I will make some and send to you to check all is ok.
