Done - 1.1.0 Ability to Rename Bookmark Categories
Discussion in 'Feature Requests' started by iMatt, Jun 23, 2015.
    At the moment you can add new categories and delete existing categories - but you cannot rename an existing category. I will add the ability to do this.
    The ability to rename categories is complete and will be included in the next update.
    Basically the swipe event that was used to delete a topic has been modified to "Edit" the topic instead. See the attached screenshots.
    iOS Simulator Screen Shot 2.07.2015 2.06.14 am.png iOS Simulator Screen Shot 2.07.2015 2.06.17 am.png
  3. sarah
    sarah New Member
    Can you also add the ability to delete unwanted scriptures under the categories? The only option right now is to reorder the bookmarked scriptures in the category but not giving us the option to choose which ones we still want to keep or delete.
    Thanks!
    You can already do that @sarah - just swipe from right to left on the scripture and hit the red "Delete" button...
